Engine is gone at 149,970 miles
#61
Given the 1MZ-FE piston heads have such indentation, I'd say that the 1MZ-FE engine is non-interference IMHO. (Otherwise there's no point for Toyota to make it that way.)
#62
That's one of them that I was thinking about. Something I was reading told me there was a slight bump in power for the ES in 99 and perhaps that was when the changeover was. There certainly weren't any Toyota Harriers, 97 and 98 model years, that had the 3.0 1MZFE, only the 2.2 L 5SFE and later the 2.4 L 2AZFE. The 1MZFE was used since about 94 in the ES/Camry.
If my rods ever go (they will one day if you wait long enough), I am getting some of these, http://www.pauter.com/toyota.htm
#63
#64
Some piston heads are designed to clear valves, thus you see the indentation. Here's a photo of such design (non-Toyota.)
#65
Any idea how new block affects MPG?
I am still a bit at loss about rebuilding the head. Maybe I should have gotten a factory new head assembly, not rebuild. Or at least new cams, gears and valve parts. Right now I only know they will replace one [broken] camshaft (out of 4), I don't know if the rest of them will stress another 150K miles.
http://www.tegger.com/hondafaq/sludg...ng_sludge.html
If you are concerned about sludge on other parts such as piston rings, Auto-RX is a safe and proven cleaner.
Did the mechanic explain to you why that rod is broken? Stuck piston ring?
#67
Auto-Rx is a proven winner. My uncle still is amazed to this day at what that stuff can do.
As far as intereference/non-interference, that was always a big debate, but there definitely was a point where there was a change over.
#69
#70
Forged rods have lighter weight, which reduces power wasted to turn these things. Some of the newer engines such as the new V3.7 in the MDX have forged steel rods and camshafts to reduce rotational mass.
Again, no one makes it. Lexmex and I are just dreaming.
#71
That is wrong with 1MZ? It is outdated or something?
#72
I am crying.
#73
#74
Update.
Sparkplugs on cylinders 3 and 5 where busted (white ceramics broke). I still trying to think why. I know that cylinder 5 rod broke, but how does it affect spark plugs? My only guess is heat buildup. But ceramics? They cannot handle it?
FYI: All 6 spark plugs are 2 month old. And, no, I did not over-torque them!
#75
Update.
