p0125
p0125
WHY IM STILL GETTING PO125 AFTER CHANGING 3 O2 SENSORS ?
BEFORE THAT I WAS GETTING P1150 AND P0125 MEETYA TOLD ME JUST GIVE IT A WARM UP THEN RESSET I DID THAT AFTER 110 MILES IT CAME BACK ON BUT ONLY THE PO125 SO WHAT NEXT?
PLS. HELPPPPPPPPPPPPPPPPPPPPPPPPPPP.
The only thing I can suggest is to clear them again.
Super Moderator
The P0125 is not a fatal error. What it can mean here, even with your sensors replaced, is that it detects certain error conditions, even for just a moment, but still the CEL stays lit. I would reset it again and try one more test.
Super Moderator
In the list of trouble areas for this P0125 code, the manual lists the following FYI:
fuel system
injection
ignition system
gas leakage on exhaust system
open or short in heated oxygen sensor circuit
As far as detecting conditions:
after the engine is warmed up, A/F sensor output (the output value changes inside of the ECM only) does not change when conditions a, b and c continue for at leate a minute-and-a-half:
a- engine speed: 1500 RPM or more
b- vehicle speed: 25-62 mph
c- throttle valve does not fully close
fuel system
injection
ignition system
StanVanDam
06-01-10 02:13 PM
