Freaking P0125
#46
Since you're driving an ES300 and this is an RX forum I doubt that the fuse boxes would be the same. Which fuse (relay) box are you checking? I know the RX has a fuse box inside as well as a fuse and relay box under the hood. IF there is an A/F relay, see if there is a matching relay that it will run without and switch them. If you know how to check a relay, take it out and use jumper wires to see if it operates. Relays are notoriously dependable. I would say many cars go to the wreckeing yard with all the original relays in them. I have an RX electrical schematic but am almost certain it would be different than an ES.
By the way, what brand of sensors did you use?
#47
