Clean Engine Bays?! PICS Please
Old 06-29-07 | 10:00 PM
cobravap's Avatar
cobravap
Default Clean Engine Bays?! PICS Please
Hey everyone, i wanna get a thread going of how clean everyones engine bay is. I will post a before and after shot once my car is in better running shape. I plan on using Simply Green (concentrated form bought from Home depot) and then water hose/ Pressure washer (will make sure to cover battery, anything else i am forgetting?) Hopefully this thread wont be deleted.
Old 06-29-07 | 10:35 PM
Lexmex's Avatar
Lexmex
Super Moderator
I did a thread where we washed the engine bay last year, https://www.clublexus.com/forums/sho...d.php?t=241019
Always an interesting thing to do.
Old 06-29-07 | 11:25 PM
zombie's Avatar
zombie
my friend says you have to wrap the alternator with a plastic bag before you clean the engine bay. if you don't, then your gonna have to wait for the alternator to completely dry before you can start up the engine again. just wondering if this is true.
Old 06-30-07 | 04:42 AM
cobravap's Avatar
cobravap
Hahaha, thanks Lexmex. I think instead we should get a sticky going of alll the DIY threads that people have started. I wouldnt have even thought that your thread would have existed. Thanks again.
Also, question: Do u think its ok to pour the cleaner and the water on top of the engine w/o engine cover there?
Thanks
Old 06-30-07 | 06:06 AM
cobravap's Avatar
cobravap
I think i read that somewhere also. Also u dont wanna do this on a hot engine if common sense didnt tell u to begin with.
Old 06-30-07 | 06:31 AM
Lexmex's Avatar
Lexmex
Super Moderator
I have heard that about the alternator, but no issues each time I do it. Keep in mind, it doesn't get drenched just sprayed in shots.
You don't want to spray too much cleaner. If you spray like you would windex, just a bit at time in spots it will work.
THE KEY AREA TO SPRAY is around the side of the engine block. This gets dirty, especially on the front and back (if you can get there like I did) and especially around the pulleys. Those of you with the URD crankshaft pulley no doubt know the importrance of keeping this area clean to ensure maximum efficiency of the pulley.
Old 06-30-07 | 10:32 AM
Meetya's Avatar
Meetya
No need to cover alternator.
Old 06-30-07 | 11:35 AM
salimshah's Avatar
salimshah
Unless you have oil leaks, get mud in the bay or never have cleaned your engine ever ..., compressed air blast is all that is needed. I have a pancake compressor that I use to fill air as well as clean out the engine bay.
To prevent oil spills, use funnel and wipe off immediately.
The problem with cleaners and water is they compromise insulation and can give wrong readings from sensors.
Salim
Old 07-06-07 | 10:50 PM
bloo1987's Avatar
bloo1987
for a clean engine bay i just had my engine cover painted
here is a pic and also i had my front bumper painted. dont worry ill fix the holes.
Old 07-06-07 | 11:10 PM
zombie's Avatar
zombie
sweet pics bloo1987! i painted my engine cover too, but my engine is still dirty.
Old 07-07-07 | 04:43 AM
Gomer1's Avatar
Gomer1
eeeeuuuuuu.....baby wipes man, that'll do trick. For rougher greasy areas, a rag and simple green. Regardless what other people might say, i would prevent getting any water there, specially at high pressure. You'll never know, and when the RX doesn't start, you'll regret it.
Old 07-08-07 | 12:40 AM
zombie's Avatar
zombie
im going to clean my engine tomorrow. might just use degreaser and a spray bottle filled with water.
Old 07-14-07 | 12:14 AM
sgv_bum's Avatar
sgv_bum
i use the camera on my phone so i made the engine look dirty ...
Old 07-14-07 | 12:33 AM
zombie's Avatar
zombie
sgv_bum...what kind of intake is that?
Old 07-14-07 | 12:40 AM
sgv_bum's Avatar
sgv_bum
blitz intake ... also i have a custom pipe that go down to bumper to suck in more cold air.
Quick Reply: Clean Engine Bays?! PICS Please
