DIY Throttle Body Removal to get at rear spark plugs
#61
The only registered props you get are thanks.
Salim
Salim
#62
Denso designed their iridium plugs to go 200k miles before performance degraded. I read (think I still have it somewhere) the paper they presented to the SAE with data proving their accomplishment. I assume NGK plugs are just as good. The problem with leaving plugs in too long is possible thread damage when removing. I always pop them at 50k, clean threads, apply a dab of AS and reinstall. I have replaced several sets at 120k miles and could never tell any difference with new plugs.
#64
#65
The next one is underneath and you can stick the extension through this area as shown.
On a side note, not the dirty part on the left, this is where most of the oil/gunk that comes through that crankshaft vent hose goes...back into the combustion. Disgusting but part of the design.
#66
#67
Is there a sticker under the hood like this: https://www.clublexus.com/forums/rx-...l#post10084755
#68
maxSteel (10-10-23)
#69
When fuel is vaporized it draws heat from surroundings and to prevent freeze up the coolant is circulated in its vicinity. Lot of science goes into engine operation.
Salim
Salim
