Differential Drain and Fill
I have changed all the fluids in the new to me 2000 RX300 - all except the differential oil.
Would you recommend I do that too ? Is there a how-to link somewhere ?
Super Moderator
This is the one I did a while back. Keep in mind for the transfer case and rear differential, this only applies if you have AWD, https://www.clublexus.com/forums/sho...d.php?t=214000
The tools need are listed specifically by some of the other members after my photos, as my uncle and I use a lot of unorthodox methods to do things.
LexMex:
Mine is a FWD. WOuld that mean there is no Transfer case ? Also what kind and how amny quarts of differential oil would I need ? Do your instructions apply to FWD models also ?
Super Moderator
However, if you did have an AWD, you would need .9 liters for the transfer case and .9 liters for the rear differential.
ToyotaLexus
RX - 1st Gen (1999-2003)
68
11-21-21 06:15 AM
