Air Fuel Sensor location
07-23-07, 06:36 AM
Where is the A/F sensor located in a 2000 RX300 ?
Can it be serviced / cleaned ?
07-23-07, 06:57 AM
Super Moderator
There are two A/F sensors and one O2 sensor.
The two A/F sensors and O2 sensor are located in the following areas noted in the next few photos.
Unless you have CEL that indicates a possibility of an A/F sensor (and even then let us know in forum what the codes are before doing anything), I don't advocate taking them out or cleaning them.
07-23-07, 06:58 AM
Super Moderator
A/F sensor: Bank 2, Sensor 1, you can see this one in the engine bay on the exhaust manifold.
07-23-07, 07:00 AM
Super Moderator
A/F Sensor Bank 1 Sensor 1, you have to crawl underneath and look up or get the vehicle up on a lift.
07-23-07, 07:01 AM
Super Moderator
O2 Sensor, Bank 1, Sensor 2. Underneath the vehicle between the main catalytic converter and resonator.
07-23-07, 07:02 AM
Super Moderator
Here is a closer look at the A/F sensor (this one is from the rear, bank 1, sensor 1)
07-23-07, 07:15 AM
Super Moderator
The O2 sensor, Bank 1, Sensor 2
07-23-07, 07:17 AM
Super Moderator
A/F Sensor Bank 2, Sensor 1 (exposed view):
Dan040286
ES - 5th Gen (2007-2012)
08-17-19 03:32 PM
Puttster
RX - 1st Gen (1999-2003)
07-03-17 10:03 AM
edupim
01-28-14 10:51 AM
martshap
Performance & Maintenance
07-08-09 04:26 PM
3warnes
17
09-28-06 11:41 AM
300 ,
af ,
air ,
cadillac ,
converter ,
diagram ,
es330 ,
fuel ,
lexus ,
located ,
location ,
o2 ,
photos ,
replacement ,
rx300 ,
sensor
