Can K&N air filter help on MPG?
Super Moderator
It can to an extent. It and some other aftermarket filters have a more free flow design compared to the stock air filter. Problem is (and one I faced) is that the oil can coat the MAF sensor. What I did was rinse off all oil and reoil a small amount on the front side of the filter (the side that goes face down in the air box).
When I had a K&N many years ago I could notice an ever slight improvement in MPG and acceleration, maybe 1 MPG.
Actually, I have used a K&N filter in my Camry. However, I was told that K&N filter cannot improve the fuel efficiency.
Super Moderator
I have been running no air filter for several years (I don't recommend this), but getting 10 MPG was not fun. For me, part of the issue is high altitude and the other is bad gas.
It might, or it might not. But it does save you $$$ from buying expensive OEM filters at the dealership everytime you service it, or even saving you from buying paper filters ever again.
I have hard many people on my other forum (Mercedes) that when they slapped on a K&N many of them had failed MAF sensors. I only run K&N Air filters on my Lexus and I have only bought one. I did the same thing as zombie. Two days before installing it, I let it sit next to my opened window (hoping the sun and wind will help soak the oil better since it seemed excessively greasy). Only thing I noticed was a slightly louder "breathe in" sound but that can be just me. Also, is it just me or is this scenario the same for everyone: On cold mornings when you're just in a rush for work...you don't warm up...and you drive...Each time the car is about to kick up to a higher gear you hear a loud noise from the engine as if it is breathing in (you actually hear the car trying to breathe-in it seems like....like taking a breath of deep air). Anybody else have this problem? Or do you guys think I just have a gasp somewhere in my air filter box? Because I noticed the box fitted more snug with the OEM air filter than the K&N.
Super Moderator
That air filter box can get warped over time. I used to wrap duct tape around it to keep the hot air out.
