Rx300 License Plate Installation On Front Bumper
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Hi all,
Texas needs license plate on both front and back.
Mine only has in the back, so I got new plates but wondering if I need to go to a dealer for bracket ($55)
or just buy two screws and screw the plate by itself.
Or can I buy a bracket at Autozone and put it?
thank you for advice.
Hi all,
Btw, just wait until a couple of months (September 1, 2007) until this Act Takes Effect:
http://www.capitol.state.tx.us/tlodo...l/HB01666I.htm
Code:
A BILL TO BE ENTITLED AN ACT relating to the number of license plates to be issued for and displayed on a motor vehicle. BE IT ENACTED BY THE LEGISLATURE OF THE STATE OF TEXAS: SECTION 1. Subchapter A, Chapter 502, Transportation Code, is amended by adding Section 502.010 to read as follows: Sec. 502.010. ISSUANCE AND DISPLAY OF LICENSE PLATE. (a) Notwithstanding anything in this code to the contrary, including Section 502.180, the department shall issue only one license plate for attachment at the rear of the vehicle for which the plate is issued. (b) Notwithstanding anything in this code to the contrary, including Section 502.404(a), a person is entitled to operate on a public highway a vehicle that displays only one license plate if the plate is attached at the rear of the vehicle. A person may operate on a public highway a vehicle that displays two license plates if both plates were assigned by the department for the registration period as a set of plates. (c) In any provision of this code that relates to the issuance or display of "license plates," "plates," or a "set of plates," the term means only one license plate. SECTION 2. The change in law made by this Act regarding the issuance of license plates by the Texas Department of Transportation applies only to the issuance of license plates by the department for a registration period beginning on or after the effective date of this Act. For a registration period that begins before the effective date of this Act, the department shall issue license plates as required by the law in effect immediately before the effective date of this Act, and the former law is continued in effect for that purpose. SECTION 3. This Act takes effect September 1, 2007.
A bracket will make it look a bit cleaner but at $55, I would rather not plus it doesn't look much different with or without the bracket IMO. The bumper should have two indentations where the screws should go. I would just use a size smaller drill to make the holes and then just screwed it on with a larger screws.
Thank you for reply Meetya.
I didn't know the law is changing, otherwise I wouldn't get new plates.
I think I'll just replace the rear plate and keep the other one in the car just in case to explain to officers that I'm planning to install it...
Kronx,
Yes, someone from dealer also said when I called to look for small pushed in dabs for installing bracket, but I have hard time finding it, everything looks smooth :-)
Kronx,
Get an oil change at a Lexus dealership and they'll probably put your front license plate on your vehicle for free! They did that for me in Sacramento.
