Disable Daytime running Lights?
Super Moderator
I tell you what, I will take some more photos tonight of the plug and the connector with the tape off. I used to have some photos that were shots from underneath, but they don't quite show the area as well.
jjbrahma (05-22-20)
jjbrahma (05-22-20)
jjbrahma (05-22-20)
jjbrahma (05-22-20)
jjbrahma (05-22-20)
jjbrahma (05-22-20)
jjbrahma (05-22-20)
Super Moderator
Now see the the little latch on top, that is what you have to push in. I actually did the first time with my thumb as it was a little tough. This latch faces downward when plugged in.
jjbrahma (05-22-20)
jjbrahma (05-22-20)
Thanks Lexmex for the explanation and for the pictures as well, however, this way is not applicable for all vehicles, I have a GS300, year 2000 and I haven't seen such connection.
i did this mod super easy just the connecter was a bit of a pain to get off gotta pull hard. i used to have only my fogs on and my headlights on when ever i wanted them on. all i did was switch the fog and low beam connecters. they are both 9006. so now you fog light on/off ring switch thing controls your headlights. its as easy as that.
I unplugged the fuse (7.5 amp) in the small fuse box under the hood in my RX 300. Owners manual says DRL system, but the lights came on when I started the car. Don't see why the lights still came on, but guess I'll just have to disconnect the plug.
