i want this :-( -/ exhaust (Merged Threads)
#46
Super Moderator
Then as you saw in the picture of the Secret Weapon Intake filter above it has a 3 inch inlet on the top of it. I will be placing a 3 inch PVC piece in there, kind of like so as I showed earlier.
#47
Super Moderator
That piece will then connect to this piece, which will of course lead to the lower air intake.
I did a similar type test about 2.5 years ago with the Blitz SUS filter, but the entrance to the filter is much smaller than the 3 inch top part of the Secret Weapon Filter.
#48
Super Moderator
(bloo1987) yeah it is looking like there's no way to do the exhaust and get the desired sound
(lexmex) ok things are looking as i planned. do you think my best bet is to go as straight as possible with an oval muffler from a company such as magnaflow + a weapon r intake? also what's your opinion on TTE lowering springs to improve corning and reduce body roll/squating/nose dives?
--thanks
--thanks
#49
ok...good ideas for the intake. as for the springs, the eibach lower the car 1.5-2 inches i think, and the TTE lower it 35mm. what springs would you recommend getting to reduce body roll/squating/nose diving and therefore improve cornering?
i think im going the the secret weapon weapon-r cold air intake + some kind of spring + something with the exhaust for starts. could you give the exact tip that you that you think i should buy for the needs im trying to meet?
#50
Super Moderator
If you are referring to exhaust tip, even the design like on the X5 is adequate or one one that is round, but should be about the size/length of that one that I showed on that APC muffler.
#51
That TTE is BS. It's just another lame M45 blower that's too small mounted on the intake manifold.
Yall do realize for $1500 the Camry M45 will mate to your intake manifolds & do a fine enough job blowing the engine up without more extensive fuel mods lol!
#52
Super Moderator
#54
Super Moderator
Supposedly , an AWD RX300 is supposed to do 16.8 in the 1/4 mile and 8.8 secs in 0 to 60 mph. Most things I have read over the years in publications show 17s. A few years back I read a Consumer Reports and it showed the RX330 (not the RX300) pegged at 17.0, but I think the RX probably runs low 17s.
I haven't had the chance to test my RX at sea level to see what it could run, but fastest up here at 7,400 feet has been 17.931.
#55
wow that's pretty cool...i've never timed my car, but it's stock so there's really nothing to test. will my car be noticeably faster AT ALL with a cold air intake? without timing it?
#57
Super Moderator
Depends how you set it up, but I notice without it in a test a few weeks back I lost a few tenths of a second, which is pretty significant.
#58
