code po125- p1150
code po125- p1150
Guys Need Your Help Here I Have Changed All 3 O2 Sensors Some Might Call Them Air Fuel Ratio. Anyway Also Did The Maf Sensor And Also Temp.sensor. How Come Pp1150 And P0125 Still Coming Up On My Cel? By The Way P1150 According To My Code Reader Is Pending.lexmexxxxxxxxxxxxxxxxxxxxxxxxxx Just Want To Say U R The Man.
Super Moderator
Only three possibilities: ECM, bad A/F sensor, malfunctioning A/F sensor. Mostly like this could be due to a connection on the front sensor.
How long have you been driving it since this occurred?
Super Moderator
Did you install this same sensor on the two front A/F sensors and the O2 sensor after the main cat beneath the vehicle?
For the two A/F sensors, that denso number is as you state, 2349009, but for the O2 sensor after the cat, it is different, it is 2344215.
Super Moderator
It's really tough for me to say definitely. Only things that come to mind are the connecting wires to the sensors itself or an issue with the installation of the sensors themselves. Sometimes, just turning the sensors a little bit more one way or another does the trick. I have seen my uncle disconnect and reconnect A/F sensors many times until he gets the light to go out. In addition, with an advanced OBDII reader, I would be able to get the readings off the banks to see if the sensors are reading everything okay, even if the sensors themselves have proper resistances.
Dan040286
ES - 5th Gen (2007-2012)
08-17-19 03:32 PM
