RX isn't fast enough
Old 09-15-07, 09:39 PM
tom44vip
tom44vip's Avatar
Default RX isn't fast enough
I have a '99 RX300 with all stock engine equipment. I know next to nothing about performance and upgrades, but I do know that my Rx is sloow.
I saw some videos and read that people are getting to redline but the automatic shifts at about 2-3. Is there any easy way to knock that number up to about 5 so I can get a little more speed? Or am I in way over my head
Old 09-15-07, 11:23 PM
HarrierAWD
HarrierAWD's Avatar
Just floor the gas. I occasionally get up to 4-5K range for my driving. Don't do it too often, or you'll blow a gasket or wear out your tranny quickly.
Old 09-15-07, 11:41 PM
TunedRX300
TunedRX300's Avatar
Instead of leaving the gear at "D", you can do gate shifting and control the RPM shift points. Both engine and tranny are designed to handle from idle to redline so 5K RPM is a piece of cake for the powertrain.
Old 09-16-07, 05:21 AM
Lil4X
Out of Warranty
Lil4X's Avatar
In most cases, while the sound of the engine thrashing away may give the impression of greater speed, a stopwatch may indicate otherwise. Pull the negative battery cable, wait ten minutes and reinstall, then go out and "retrain" your engine/transmission for your driving habits. The ECM is probably able to make more informed decisions than you or I, particularly in straight line acceleration. I will defer to our resident RX drag expert, Lexmex for the definitive techniques for low ET's. He has a bucket of timeslips to support his advice.
Old 09-16-07, 06:54 AM
Lexmex
Super Moderator
Lexmex's Avatar
Tips hat to Lil4X
Tom44vip, all mentioned above by my colleagues is excellent advice and I'll try to add from my experience.
One thing I recommend immediately to do is adjust your throttle cable. Move the nuts to the left in the direction shown below. This will give a better throttle response (this was an idea of Pheonix over in the ES forums).
When I drive at the track I always use PWR on and overdrive off, and the PWR on will hold those RPMs longer (you may have seen my videos on youtube). However, on the street, PWR is off and overdrive is on. PWR on and overdrive off unfortunately eats up gas.
Lil4X mentioned resetting the ECM and this is absolutely necessary. Your RX's computer is hitting those shifts where it does because it has a history of that occurring. Same reason I reset my ECM before going to the track, to get my history of commuter driving out of the computer and get it prepared for hard grinding action at the track.
Thing to do is adjust accelerator cord, reset ECM, and then drive hard at the light and on the highways, a.k.a., when you are going to hit the gas, hit it with some authority, not half way down not a 1/4 of the way down, but at least 3/4ths of the way down, enough that you can hear the engine roar. This takes by my calculations at least an hour or so of driving it around, but you have to keep it up.
Bad thing about this, is that inevitably this will eat up more gas and put strain on the tranny.
Only other steps are to modify things like I have done, exhaust and air intake, especially exhaust.
Old 09-16-07, 08:22 AM
tom44vip
tom44vip's Avatar
Wow, thanks. I'm going to do this first chance I get.
TunedRx300, I'm not familiar with the term gate shifting. I assume you're talking about rev'ing in Neutral then switching it up to D?
Thanks for the tips though!
Old 09-16-07, 01:56 PM
miniround
miniround's Avatar
tom...
gate shifting is when u turn off OD and shift it down into L and then when you want to shift into 2nd (yea you can bounce off the limiter!) you just shift up to the 2 position and then when you want to shift again you go back up to D. I've tried to launch with N->D, but it doesnt work haha. and Lexmex said to not hold down the brake and gas together cuz you could drop the tranny!
and also, def do the throttle body tightening...i did it and there's a definite difference. Lexmex is basically the RX man, no not a doctor, and he's always available to help!
Old 09-16-07, 02:28 PM
zombie
zombie's Avatar
how many miles do you have? since your rx is a 99 its probably close to or pass 100k? have you changed any of your spark plugs or a/f sensors yet? if not...you should probably do that and then the rx would feel a little better.
Old 09-17-07, 02:23 PM
TunedRX300
TunedRX300's Avatar
miniround explained gate shifting perfectly. Here is a dyno on a AWD RX300, it is pretty self explanatary on higher power output vs. rpm.
Old 06-01-08, 09:17 AM
archangels
archangels's Avatar
lex so move left nut closer to that rubber grommet piece and tighten right side close to braket? so eventually is the cable were nuts are on but not the cable wire the black cable should be going to rightand nuts to left so left nut goes closer to grommet blackrubber and tighten the right nut to bracket? it hard to tell because i think mine looks a little longer then the one pictured... thanks lex thanks
Originally Posted by Lexmex
Tips hat to Lil4X
Old 06-01-08, 10:28 AM
tcheung87
tcheung87's Avatar
I think that's about what my '95 Celica GT does, maybe even worse.
Old 06-01-08, 05:08 PM
miniround
miniround's Avatar
haha. it's funny how after like 4300 the power really does go away. there's only a fun amount of torque inbetween 3 and 4k rpm...
Old 06-02-08, 07:44 AM
lexus114
lexus114's Avatar
Keep in mind,that this vehicles is around 4,000 lbs.(if I remember correctly) and that is asking a lot from this motor and trans.Also,this motor generates max torque sooner than you would expect.
Old 06-02-08, 09:18 AM
TunedRX300
TunedRX300's Avatar
Max Torque is ~4400 RPM, an unlikely event if one shifts to "D" and left it there.
Old 06-02-08, 10:15 AM
lexus114
lexus114's Avatar
80% of the 3.0`s torque comes in @ 1600 rpm
Quick Reply: RX isn't fast enough
