how to clean under 2nd row seat
I know this is probably a dumb question, but I can't figure out how to pull out or lift up the second row seats to clean under them. I have 3 kids and there is an entire toy store + cereal isle under there.
thanks for the help.
under/behind rear seats
My dog barfed a stomach full of salmon, directly down the seatbelt hole.
I knew I had to do a exceptional clean up job. I removed the larger of the two back seats entirely. It wasn't too difficult.
You'll need a screwdriver to remove the screws holding the fabric sleeve to the back deck, and a ratchet wrench with a deep socket to remove the seat. It'll take about a 1/2 hour to remove the seat, and about 20 minutes to re-install it.
If you don't remove the seat, you won't be able to get to every spot. In my case, I had no choice...I had to remove every bit of spilled material on the floor AND on the underside of the seat, or risk permanent stink.
Good luck.
Good luck.
tomstep2
RX - 1st Gen (1999-2003)
03-20-09 03:05 PM
