2002 Rx300 A/c
Other than a hard failure (for which repairs have to be done ...a/c shop or dealer) it happens when you go through a large puddle splashing water on the belt. Once things dry up and you restart the RX the blinky goes away.
Salim
Salim
Mine did that a while back, cycled the defroster and it stopped blinking and the ac kicked on...... if the compressor is turning, you can view the sightglass for the refridgerant level in front of the radiator. It should look full of liquid with an occasional bubble, lots of bubbles or foamy look after the system has been on a while indicates low freon....
TURBO300RX
10-03-06 07:41 AM
