no heat in cabin after changing spark plugs
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
My wifes car is not home yet, but the heater hoses come out on the left (driver side) of the firewall. Look in that area near the rear plugs and see if you smashed the pipes or if there is a valve for the heater lines. I didnt think there was, because Lexus mixes hot and cold to achieve temperature settings, but maybe there is....I will check When wife gets home....
Blind guess ... electrical connector that got disconnected or you might have forgotten to re-connect.
The other guess would have been vacuum line, but that I think is not used to activate heat.
Salim
Salim
As mentioned above, most cars have a heater control valve of some kind that bypasses the heater core when it is not needed. My guess is that you knocked off a vacuum line or cable the moves the valve. Just a guess.
morehwr:
You may noticed a revival of thread
https://www.clublexus.com/forums/sho...d.php?t=246269
I am listing it here in case a search brought some one here in future.
Salim
Salim
gemineye
03-08-11 05:33 PM
