A few small things I did on the weekend
Super Moderator
I think about every weekend for the rest of the time I have my RX300 I probably will find myself tinkering with it. In addition to the coolant change out that I did, I also found the time to do some minor maintenance work on the steering wheel and also a small modification to the lower air intake.
We'll start with the steering wheel. A repeated problem I have had was some minor vibration that I occasionally get that cause the wheel to turn to the right. After doing what I am about to show, we realized the center bolt was tight and that the real culript was the replacement cartridge I used on my front passenger shock absorber, so I will need to replace that cartridge (the replacement one that I am using is a bit smaller, modified from one off of an old Pathfinder, but it has done the job).
Well, first the steering wheel.
Super Moderator
We wanted to take a look underneath where the airbag is so we first had to take out the two plastic covers on each side, here is the one on the right removed with a flathead.
Super Moderator
Then my cousin Rodrigo demonsrates putting in a T20 Torx wrench. This will actually (even with the vehicle off) cause the horn to sound. Thus, we disconnected the battery to avoid ticking off the neighborhood.
Super Moderator
This actually wasn't easy on this side, and the bolt actually ended up staying in. In the manual, they tell you that you just need to loosen it up, but we found we at least had to remove one on the other side. This is how it wound up on this side.
Super Moderator
Now, that center bolt we didn't remove. For the life of me, I can't remember the size, but I estimate it was close to the size of the transfer case bolts. Only thing we did was put a wrench on the top and see if it indeed was tight. We then took the vehicle over for an alignment with a friend of my uncle's who has an advanced Hunter machine to also check rear alignment and we were able to determined the front right shock was still the culprit after a careful inspection of other suspension pieces.
Super Moderator
Now, you might remember this thread, https://www.clublexus.com/forums/sho...d.php?t=298404
Well, this turned out to be so-so. Part of the problem is that the lower air intake designs I have used are still very much an L (we'll get to that in a bit). What I realized is that the air was taking too long to reach the engine on this design and it needed to be more angled.
Super Moderator
So I decided to take out the old piece and modify it. First I start at the top and placed angled PVC piece to aim directly toward the front hole in the bumper as shown.
