Gear shift console light out
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Hi!
Was wondering if anyone could help me out.
I have a 2001 RX300 which has the gear shift light out (not on the dash but where you actually shift ). Can't see P R N D L1 L2 in the dark. Also the green light around the key ignition is also out. What do you think is the problem? Thanks!
Yes, funny, I too was just looking at that the other day trying to recall if the shift indicator next to the shifter was supposed to be lit, it seemed odd it was dark there. Hoping this one is easy to replace. And I just lost the D-light on the instrument dash area that has been discussed on other threads with some great DIY posts. FWIW, my green ignition key light is still on, how long?
I wish Lexus were using longer-lasting bulbs for these hard-to-reach areas, my car isn't even 5 years old.
Parula, I work for a Lexus Service Center near Washington D.C. area and i see those bulbs out all the time there just crappy bulbs i have replaced 2 bulbs already.If it helps you out any the part number for the bulb is 90981-11018 and they list for $5.11.
Mat, thks, I need help with how to get access to that area to change the bulbs on the shift console, haven't searched CL yet. Tell Lexus to use high-voltage bulbs or something that will last a real long time.
There indeed is a light in the shifter area because I just checked mine and it's lit. I have never changed it, obviously, but looking at the area, it would take a minimum of removing the whole bottom area of the area and then possible some side panels. I've replaced the dash light, and it took a while for that. It's just me, but when I shift, I don't really even look at the shifter, I look at the gear selector on the dash. I would say the effort might not be worth the gain of having the shifter area lit.
and it’s on the dash board but it chugs going out of second
After being involved in a freak but minor accident, I can attest to "tunnel vision" ... as my eyes focused and vision narrowed to the instrument cluster, I am for fixing all lights in the dash. I tell you that you them all.
Salim
PS: The "D" light bulb was upgraded by Lexus and the new one lasted over 200K miles for me.
Salim
There is a little bulb with a green rubber jacket like thing that goes over the bulb at the shifter for the shift indicators. You will need to remove the trim that surrounds the shifter area in order to access the bulb. Mine was blown as well and I replaced it using instructions that I found on this forum somewhere.
