Trans Oil, can't get a good read
I always do a warm reading. I agree that right after filling the darn thing with your fluid, it smears the heck out of your dip stick. It's a futile effort, really......
I measure how much came out.
I refill with same amount as amount that came out minus 1/2 quart.
I let it rest for about 30 minutes.
I take a cold read.
I drive it to work.
I take a hot read and refill what I ever I need.
I do the same thing again the next morning.
I don't know why but whenever I do drain and fill from a dealer or repair facility, they always overfill......
I take a cold read.
I drive it to work.
I just did another drain and fill and noticed that 3.7 quarts came out (and refilled).
I don't get it
There can't be that much in there. At least 1 qt should be left in the torque converter.... because the total capacity, I believe, is 4.3 qt.
Anyone with an explanation???
I don't get it
I don't get it
I don't get it
This is the reason we're suppose to do a drain and fill 3-4 times.
Are you taking the plug out of the differential too? There is at least 1/2 a quart in there.
I have done 4 or 5 drain and fills now and the 4.3 thing seems very close to me. The first time I did it I measured what came out and replaced the exact amount. What a waste of time! It needed a little more than what came out, it was probably a little low in the first place. Turned out to be about 4 1/4. Now I just pop both corks and let it all drain out. Put in the plugs and put a little over 4 quarts back. Drive it around for 15 minutes and check. It is always with in a 1/4 of a quart.
I think total capacity is closer to 8 quarts. There is some incorrect info on the net regarding that number.
I know this sounds stupid but.... I don't know where the differential drain plug is. The last time I did a drain and fill, I got it confused with the transfer case (mine is AWD) and didn't bother looking for it. Another reason is: I have this phobia that my car is going to come crashing down on me if if I use a jack. So I hate to venture down there. Basically, I do my drain and fill without lifting the car at all.
It is the one pictured here with the allen wrench in it.
![](https://www.clublexus.com/forums/attachments/rx-1st-gen-1999-2003/91893d1159503542-photo-diy-rx300-awd-transmission-fluid-pan-filter-change-rx300-frontdiff-drain.jpg)
Another shot minus the wrench.
![](https://www.clublexus.com/forums/attachments/rx-1st-gen-1999-2003/108972d1185804118-photo-diy-rx300-awd-transmission-fluid-pan-filter-change-img_2822.jpg)
(pics borrowed from Lexmex)
As long as you are just using the 10mm allen wrench it is impossible to screw it up. The transfer case is a hex head pictured here:
![](https://www.clublexus.com/forums/attachments/rx-1st-gen-1999-2003/84069d1146353406-rear-differential-and-transfer-case-diy-transfercaseplug.jpg)
You can get to both the transmission and differential plugs without lifting car.
I just use one catch pan and drain the fluid from both plugs at the same time into the same pan.
Bawlzdeep
Performance & Maintenance
03-06-13 09:01 PM
