Something went bump :(
Old 11-27-07, 02:05 PM
Lexmex
Super Moderator
Lexmex's Avatar
Side view, you can see in the upper left where the starter goes in and connects with the flywheel/driveplate.
Attached Thumbnails Something went bump :(-img_3566.jpg
Old 11-27-07, 02:06 PM
Lexmex
Super Moderator
Lexmex's Avatar
Another shot.
Attached Thumbnails Something went bump :(-img_3567.jpg
Old 11-27-07, 02:07 PM
Lexmex
Super Moderator
Lexmex's Avatar
Another shot. See that little valley or drop on the back that is where that rear drain plug are is I talked about once.
Attached Thumbnails Something went bump :(-img_3568.jpg
Old 11-27-07, 02:09 PM
Lexmex
Super Moderator
Lexmex's Avatar
Where front differential is and where drive axle goes through.
Attached Thumbnails Something went bump :(-img_3569.jpg
Lexmex
Super Moderator
Lexmex's Avatar
Now you can see the light through it.
Attached Thumbnails Something went bump :(-img_3571.jpg
Old 11-27-07, 02:12 PM
Lexmex
Super Moderator
Lexmex's Avatar
This is where we think our culprit is, where the torque converter hooks on. And perhaps the torque converter itself.
The flywheel/drive plate is quite firm.
What we think happens is that the torque converter is loose and is banging around the sides of this area, just enough and wham, fluid pops out, too.
Attached Thumbnails Something went bump :(-img_3572.jpg
Old 11-27-07, 02:13 PM
Lexmex
Super Moderator
Lexmex's Avatar
Ah, the flywheel/drive plate, this is what the torque converter hooks on to.
Notice my exhaust piping and no precat. Also note in the lower right the transfer case where the axle goes through.
Attached Thumbnails Something went bump :(-img_3573.jpg
Old 11-27-07, 02:15 PM
Lexmex
Super Moderator
Lexmex's Avatar
An axle, driver's side. Other one has those clamps I put on.
Attached Thumbnails Something went bump :(-img_3574.jpg
Old 11-27-07, 02:16 PM
tcheung87
tcheung87's Avatar
It's like looking at pictures of a surgery. Hope everything goes well for you Ron, I mean while you're in this position you might as well install a high performance TC. Kidding of course.
Lexmex
Super Moderator
Lexmex's Avatar
Another look at drive plate, transfer case area.
Attached Thumbnails Something went bump :(-img_3576.jpg
Old 11-27-07, 02:17 PM
Lexmex
Super Moderator
Lexmex's Avatar
Closer shot of drive plate.
Attached Thumbnails Something went bump :(-img_3577.jpg
Old 11-27-07, 02:19 PM
Lexmex
Super Moderator
Lexmex's Avatar
Well, that might not be out of the realm of possibilites. This guy we are going to can make them. Keep in mind the truck was working just some noise in the torque converter area and fluid leaking. No CELs, but again not safe.
Old 11-27-07, 02:20 PM
Lexmex
Super Moderator
Lexmex's Avatar
Lines for the tranny cooler.
Attached Thumbnails Something went bump :(-img_3579.jpg
Old 11-27-07, 02:22 PM
Lexmex
Super Moderator
Lexmex's Avatar
Rear manifold, no precat.
Attached Thumbnails Something went bump :(-img_3581.jpg
Old 11-27-07, 02:23 PM
Lexmex
Super Moderator
Lexmex's Avatar
Near where thermostat goes.
Attached Thumbnails Something went bump :(-img_3582.jpg
Quick Reply: Something went bump :(
