Shocks KYB GR-2
#92
Super Moderator
I have 110k miles on my '01 RX300 and need to replace all of the struts. Can someone please let me know ALL the parts needed, e.g., struts, bellows, mounts, etc. Or are these struts that come with all of the necessary parts? Thx
#94
PS For some reason, the rear strut mount comes with a new rubber bellows to protect the strut making the rear strut mounts more expensive. My old bellows were in pretty good shape front and rear so I wasn't too happy about having to buy new rear bellows but what are ya going to do?
#95
Let me echo what ArtBuc says. The only KYB parts you want to buy are the struts themselves; bellows, insulators, and mounts need to be OEM, or the tubing suggested by LexMex for the insulators.
Also, when I did mine I was unable to remove the rear sway bar end links without destroying them, although I was able to reuse the fronts.
#97
Does the suspension support (also called mount) needs to be aligned/position when assembling it on the strut, to make sure it goes back to the hole on the RX and place the nuts. how ?
Thanks (I really love this forum, and people here are very helpful).
#98
Super Moderator
Yes, it does to go into the 3 holes at the top, but that shouldn't be hard...are you running into trouble on this?
#99
Hi Lexmex,
not really, I am just preparing for next week. My KYB strut arrives (ordered from AJUSA) already painted black, and the other parts (ordered from mylexparts.com) inclusive of the mount, bearing, insulator, bumper... except spring will come Tuesday. Thanks for tis thread and posting.
-mike
-mike
#100
I just put KYB GR-2's on one daughter's Olds Intrigue, and I'm planning to do it on the other daughter's RX. Does anyone know the torque settings for all the bolts removed and replaced?
Thanks!
Thanks!
#101
Front:
2x camber bolt nuts (7/8") 155 ftlbf
1x Stabilizer bar link (14mm) 29 ftlbf
1x ABS/Brake hose nut (12mm) 21 ftlbf
3x support mount (14mm) 59 ftlbf
1x strut 36 ftlbf
below are the road blocks I experience,
1. to remove the nut (14mm)on the stabilizer link, I have to hold stabilizer link using vise grip (8mm wide jaw). see photo. allen hex key to hold the thread did not work for me.
2. cannot compress far enough the coil using manual tool, I got to use an impact wrench.
1x strut 36 ftlbf
#103
Great detail, thanks!
I need to take my '99 2WD to a shop to replace all struts, mounts, bearings, rubber, etc. The handling has always been too soft for my tastes, and I'm looking for ways to stiffen up the cornering/leaning. Lexus has not been supportive of handling mods (like larger anti-sway bars) and I have not been able to find anything aftermarket.
Does anyone know of any suggestions to tighten things up?
Are JDM Harrier struts any better than stock, KYB, or Monroe? Any suggestions how to source these properly?
Are the KYB (aftermarket) or Monroe any better than stock (KYB)?
What sources have you found for RX300 suspension mods? Anything like a larger/stiffer sway bars and bushings?
Thanks folks!
Thanks folks!
#104
I've tried to find a part number for the Silversport's sway (stabilizer) bars, however no luck yet.
Did the Silversport have different bars, or was the only difference in the springs?
Do you (anyone) have a suggestion how I can find part numbers?
Thanks...
Thanks...
#105
to trhs75,
Manual says torque setting for the rear as,
Rear:
2x camber bolt nuts 188 ftlbf
1x ABS speed sensor 44 ftlbf
1x Brake hose nut 21 ftlbf
1x stabilizer bar link nut 29 ftlbf
3x support mount 29 ftlbf
1x strut 36 ftlbf
Rear:
1x strut 36 ftlbf
