RX300 Transmission problems
Hello,
My RX300 transmission failed just under 100K miles. $5K to repair. Just a month later transmission is not shifting into higher gears. taking to shop again. A friend told me the exact same thing happened to her RX300. The transmission failed at just under 100k miles.
Anyone else experiencing transmission failures witht he RX300 (Camery drive tran)?
- RX300ownde
- RX300ownde
Welcome to club lexus.
If you do a search, you will hit various threads on RX300 trans failure. Fellow member thomas1 is keeping a count.
Please post what exactly was found wrong with the transmission. (last time and this time).
Since the failing part has not been identified, we are all at a loss .. some feel it is the pump, some feel that the fluid should be replaced more frequently.
Salim
Salim
boo1678
RX - 1st Gen (1999-2003)
03-19-13 11:15 PM
