how to change fuel filter on lexus rx300
#32
Sometimes the float is integrated with the fuel pump unit on some cars, the rx300 has a separate unit specifically to tell how much gas you have. The black part on the hanger is the float that floats on the fuel and sends a signal to your gauge as it goes up and down.
#35
#36
I don't know what it is about this topic, but people are simply not understanding what I am saying. So indulge me while I used the dreaded ALL CAPS. MY RX STOPS RUNNING SHORTLY (I.E. WITHIN TEN MILES) AFTER THE LOW FUEL LEVEL LIGHT COMES ON ALTHOUGH I KNOW FOR A FACT THERE ARE STILL 3 TO 4 GALLONS OF GAS IN THE TANK. (PREVIOUSLY I COULD DRIVE 50-60 MILES AFTER THE LOW FUEL LEVEL LIGHT CAME ON.) I ADD ONE GALLON AND THE CAR RESUMES NORMAL OPERATION. BUT IF I DON'T THEN FILL THE TANK (OR AT LEAST ADD SOME MORE GAS), THAT ONE GALLON WOULD LAST ME 20 MILES MAX UNTIL THE RX WOULD STOP RUNNING AGAIN. AND, THAT FILL-UP WILL BE NO MORE THAN 13-14 GALLONS ALTHOUGH THE TANK CAPACITY IS 17.2 GALLONS. ITS AS IF FOR SOME REASON MY FUEL INTAKE PICK-UP, WHICH HAD PREVIOUSLY BEEN VERY NEAR THE BOTTOM OF THE TANK, IS NOW SOME DISTANCE HIGHER UP. THE PROBLEM IS DEFINITELY NOT THE FUEL LEVEL SENDER OR FUEL GAUGE.
#37
#38
Fuel filter
I replaced the fuel filter in my RX, I thought it was pretty easy. But I have replaced over about 5-7 fuel filters that were in the tank before. The only plus about the RX, is the access hole on top for the pump. It makes it a lot easier than dropping the tank. I did that once to help a friend, never again. I will only help out with the access from the top.
