01 rx300 flashers will not turn off
What would cause this? I was driving and the 4 ways came on and will not turn off even when the ignition is off. I ve checked all of the fuses and they are fine. I disconnected and re connected the battery and they stopped for about a minute and then started flashing again.
. Thanks for any ideas or help.
UPDATE: Problem Solved. The hazzard switch itself was malfunctioning. Unplugged the switch and problem ended. Ordering a new one tommorrow.
Flasher get activated when:
The hazard triangle is pushed.
or security system is engaged.
I suspect the the last is malfunctioning.
Salim
Salim
Thanks for the reply, The triangle is not pushed. The lock system and key fob are working properly. I wonder if there is a way to de activate the security system to see if thats the problem?
Sorry, my last post was ambiguous. The Lock/unlock may work fine but the lock-unlock to flasher signal can be bad.
I do not have the electrical diagram to comment more.
As wild guess, [if this is a software problem] disconnect your battery for about 20 minutes and see if the problem goes away. You will loose all settings, except the key codes.
If not, I would suggest a visit to the dealer.
Salim
Salim
Salim
Salim
I hope the switch IS the problem. Once again I wish I had the electrical diagram to check this out.
There is a slight possibility that by disconnecting the switch you are essentially removing sockets of each flasher.
Keep us posted.
Salim
Keep us posted.
Salim
