120,000 mile "service"
Old 05-26-08, 03:59 AM
lastplace
lastplace's Avatar
I've purchsaed amsoil atf in qts and 2 1/2 gal containers, right now it's about $10/qt.
Old 05-26-08, 06:22 AM
Lexmex
Super Moderator
Lexmex's Avatar
We've discussed the issue you mention many times on this forum. OEM tranny fluid is not synthetic, it is an ExxonMobil fluid. Amsoil would be your better bet as it is synthetic and I as I recall we have had not a single issue with someone using it in our RX300s, if nothing else, positive performance. Take a look at Amsoil's site, www.amsoil.com
You can get it different sizes, but at the Carquest I went to they only had quarts.
Old 05-26-08, 11:51 AM
archangels
archangels's Avatar
how many quarts does it consume on drin and fill
and how many consume in drain then dropping pan and refill, is there a certain weight i need to buy? i am thinking of using amsoil but will use oem tranny oil as i already bought it... but next 15,000 i think i will start using it...
Old 05-27-08, 05:29 AM
Lexmex
Super Moderator
Lexmex's Avatar
When I did my last drain and fill, I used 4 quarts on the dot after draining the front differential and tranny pan.
need4spd90
08-13-06 05:42 PM
IsraelRX
17
09-04-04 05:01 AM
SC400-V8
Maintenance
06-14-04 02:21 PM
PhoenixGold50
10-20-02 11:25 PM
Purplexed
05-21-01 11:10 AM
Quick Reply: 120,000 mile "service"
