Good Deal : Replaced timing belt+ for $666
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Just got the following replaced for $666 this weekend at an independent shop in Fremont
1. Timing Belt
2. Tensioner
3. Idler
4. Drive Belts(2)
5. Water Pump
6. Cam Seals (2)
7. Thermostat
8. Gasket for thermostat
9. Coolant
all parts and fluids used were Toyota Genuine and were verified before and after. The shop is Nippon Auto Repair in Fremont, CA
1. Timing Belt
2. Tensioner
3. Idler
4. Drive Belts(2)
5. Water Pump
6. Cam Seals (2)
7. Thermostat
9. Coolant
Any warranty?
Salim
Salim
You did a lot better than me:
1. Water Pump
2. Thermostat
3. Thermostat Gasket O-ring
4. Radiator hose upper
5. Radiator cap
6. Radiator hose lower
7. Coolant
8. Crankshaft seal
9. Camshaft seal
10. Oil Pump seal O-ring
11. Timing Belt Kit
12. Multi V-Groove
13. Multi V-Groove
14. Brake light bulb
1 year/12,000 mile warranty - $1,249.19 in Los Angeles.
1. Water Pump
2. Thermostat
5. Radiator cap
7. Coolant
8. Crankshaft seal
9. Camshaft seal
11. Timing Belt Kit
12. Multi V-Groove
13. Multi V-Groove
wow, are all those other stuff like seals, etc work changing?
I changed my own Timing belt and the only additional thing I changed was this bearing inside the power steering pump that I saw started to leak.
