premium octane fuel? 87 vs 91?
They recommend premium for 2 reasons:
Firstly to allow the engine to operate at it's optimum timing - 87 octane willlikely cause the knock detector to kick in a retard the timing loosing some performance and some economy (yes).
Secondly, premium gas contains (more) detergent than regular to keep everyhting a little cleaner.
It probably hasn't done the car any damage but you actually don't gain much by cheaping out!
I'm on my second RX with 129K on this one. Nothing but 87 octane except for some tests with premium. No difference in economy or power. Never had a valid CEL and I changed the plugs at 125K and they looked like new. For the last about 80K I have been using an off brand, called Delta in NJ, without any problems. Problems with less detergent in regular and off brands was fixed over 10 years ago but the rumors still exist.
Since I have gotten back to the U.S., I have experimented with a number of fuels. Sometimes correcting assertions I made earlier. The two gasolines I have tied for #1 are Sunoco Supreme Unleaded and Chevron Supreme Unleaded. I seem to get the best mileage on them and the lowest number of CELs running these two. I have also seemed to have a good, but not as good as the top two, running Mobil (even though I don't like running Mobil1 for my oil anymore)
Top name brands that I have had issues with on mileage and CELs (especially A/F sensor codes, not just P0171 errors): BP, Shell.
I plan to give Shell another shot next time I fill up (though I suspect nitrogen is a sheer marketing ploy on Shell's part). My girlfriend has had a CEL virtually everytime she has filled up with BP with her Expedition, though sometimes the cel (an A/F sensor) is pending as I check it when the vehicle is back after having filled up.
However, I'll gladly take issues as such over the garbage I had in Mexico. See my comment in post 10 of this thread made when I was still in Mexico.
I think thats how all the stations do it.What I would be curious to know is,is the 89 octane enough to keep the timing advanced for performance? Seems mine still has the most power on the 92-93.(I have tried all three grades) but if gas goes up to $4.00 a gallon again,I`m going back to regular.The real strange thing about using regular gas is,in the summer it actually runs pretty good on it.(once it figures out where to adjust itself) but as soon as that winter blend crap comes out,forget it! Runs like garbage then.(should be the other way around,cool air in winter vs.warm air in summer)
I might have tired lower octane in Mexico at the 7000+ altitude I was at, but for the few times I tried it (and knew from others experience) what foul garbage it was compared to premium (which was basically the lesser of two evils for many years until they started to make some progress in improving the premium).
The problem with gas today is that it's a commodity. It's bought and sold at various stages of the refining process. My understanding is that most of the major oil companies and all of the smaller ones sell oil/gas between each other. So by buying "Shell", "BP", "Chevron", etc, you don't really know whose gas you're getting (and I'm not sure it really matters).
I used to run regular in my rx300 when i first got her. Then for some reason i went to premium (91) for quite a while. I didn't really notice any better performance, but i did notice a tank lasted longer.
Then one day i tried to go back to regular and the car made knocking noises. So i've been back on premium.
I figure it will get me better mileage and save my fuel filter and sensors.
