torn front brake caliper boot
I just finished changing my front brakes on my 2000 RX300 FWD, and noticed that the right caliper boot is torn. It doesn't seem to affect the functionality of brakes. Does this need to be replaced?
If so, what are the steps? Is it straightforward? Simply drain the brake lines, then replace the caliper?
btw, changing the brakes are very simple and straight forward. Even easier than removing the dang oil filter.
The safe answer is always replace the boot or entire caliper. If you are sunny CA I would probably drive it for a few more years knowing that at some point it will need replaced. I think there is an overhaul kit for around $20 if you wanted to repair it. You just risk getting dirt in there and scoring the piston ruining the seal. I have driven other cars for years with torn boots. It's one of those things that I fix within a few months on my wife's car or whenever it fails on mine.
fyi, here's the repair kit for $6.59.
http://www.partsamerica.com:80/Produ...pe=223&PTSet=A
rxlex300
RX - 1st Gen (1999-2003)
06-22-11 07:29 PM
