how much can I expect to pay to replace all 4 shocks at Lexus or Toyota dealer?
my RX300 has just reached 100,000.... I'm wondering if new shocks are
needed...
Thanks!
needed...
Thanks!
Test for shocks:
Park at a level surface.
walk to each corner and push the end down and let go.
If the shocks are fine, RX should spring up, then come down (almost half way) and stop. If the shocks are bad , then after letting go, the RX will bounce up, then down and up again.
If you drive on paved (smooth) roads the shocks can last more than 100k.
For Lexus repair cost, give them a call and find out.
Salim
Salim
Test for shocks:
Salim
Salim
shocks. (prices do not include 4-wheel alignment afterwards)
Dealer location
Honestly, I got the vehicle used at 44K and after the change, didn't really feel any difference at all with handling or feeling any tighter. Still feels like a big floating boat... just the way I like it...
I went in at about 98K with a 'clicking' noise that was occuring during hard cornering, and the stealership said it was the front passenger side shock that they were done and causing the clicking and leaking. They said the other three looked bad too and were probably going to go soon, so he said he could do all four and give me a "discount." Ended up being $1480 before tax for all four and alignment.
It's got a better turning radius for one. I very much liked the handling of the RX330 the first time I took a drive of one and over Christmas last year took a drive of the RX350 and also an excellent handling vehicle. The handling/steering was one of the major things that people complained about with the first gen RX, so no doubt they sought to improve this.
I can tell you that replacing shocks on the RX300 is not rocket science. Any independent shop should be able to do this for a lot less than Toyota or Lexus. The major issue is compressing the springs. Literally, if I had a spring compressor I could do this myself right in the same place where I park.
I will be doing this myself and have a spring compressor and all the other necessary tools, but even at discounted prices from on-line suppliers the parts involved appear to cost about $1,000. And although I am certain that the insulators, bump stops, maybe mount plates, etc are bad (noticeable clunks, etc.) I am not convinced that the struts themselves have failed. However, if I'm going to take everything out and apart, it doesn't seem to make sense to not replace the struts while I'm at it. Anyone disagree?
Going fast, see Tire Rack, http://www.tirerack.com/suspension/S...lar=&brand=all (note that the AWDs are different in the rear).
KYBs are what I have.
