Nakamichi Amp Problem
The driver's side channel of my Nakamichi system intermittenly cuts out (at least I think it's the whole channel- it may be just the door speaker but it's hard to tell). It's almost always at low volumes; turning up the sound causes the left hand channel to kick back in again. At higher volumes it doesn't seem to cut out. Is it the amp? Where IS the Nakamichi amp in a 2000 RX300? This is driving me nuts and any help would be appreciated.
Thanks
Thanks
The amp is between the rear seat and the trunk- under a black metal panel
Fold the seats down- take everything out of the trunk-mat-unbolt cover- get a panel popper take out the rug part in the trunck that meets the rear seats.
Then you will see the black floor panel- its 3-4 bolts on top and 3 bolts on the back floor all 10 mm
there are panel pins on each far end of the black panel that is under the carpet. cant see them but they are there.
Amp is right there- mine is shot and I cant find anyone out there that has a replacement- if you find one can you let me know where you got it
thanks
Mike
thanks
Mike
CubFan22
RX - 1st Gen (1999-2003)
05-21-13 08:41 AM
High PSI
SC400 / 300 Classifieds
11-11-05 01:46 AM
BigghookUp
07-09-03 10:10 PM
