All 2001 rx300 please advise!!! Check engine?
Old 03-28-08, 04:22 PM
archangels
archangels's Avatar
Default All 2001 rx300 please advise!!! Check engine?
i just bought a rx 300 2001 a day before easter and want to know if there was other folks who owned a 2001 rx 300 and had there check engine light go on? i drove about 60 miles and in between those miles it came on and said check engine? the dealership said that it can be a gas cap not tight? i removed gas cap and retightened and the dealership said after 50miles the light will go off? i drove alot more then that and it stays on? i was wondering if other folks experience this? and was was wrong that made it go off? i heard before that someone in this forum had the similar problem? thanks
Old 03-28-08, 04:29 PM
Lexmex
Super Moderator
Lexmex's Avatar
Could be something even worse, but either try this https://www.clublexus.com/forums/sho...8&postcount=15
or have the code read at AutoZone and let it us know what it is.
Old 03-28-08, 06:48 PM
bob2200
bob2200's Avatar
The check engine light going on is fairly common with new-vintage cars.
I wouldn't be surprised if the majority of RX300 owners have had a check engine light come on in the first 60,000 miles.
It could be something as simple as a gas-cap seal, or something more expensive to repair. As LexMex said, if you get a readout of the code/codes we can give you some ideas from there.
Old 03-31-08, 10:50 AM
archangels
archangels's Avatar
Default reply
thanks i bought a ob2 this weekend i will see what it says? where do i plug the ob2 reader and where is the connector plug located? thanks
Old 03-31-08, 11:46 AM
Lexmex
Super Moderator
Lexmex's Avatar
Right here
Attached Thumbnails All 2001 rx300 please advise!!! Check engine?-obdiiarea.jpg
Old 03-31-08, 11:48 AM
Francis-99
Francis-99's Avatar
Under the steering wheel. Very close to the hand brake.
Old 04-03-08, 10:16 AM
archangels
archangels's Avatar
Default reply
Originally Posted by Lexmex
Right here
thanks buddy for your help, also where can you buy those nice looking pedals for these especially chrome? thanks
Old 04-03-08, 12:18 PM
Lexmex
Super Moderator
Lexmex's Avatar
Those were some Momos I got down here and then I trimmed off the black padding. I always loved the IS300 pedals and that was the idea there. Actually my HyperRev magazine showed these same exact pedals as a modification. They are actually called Momo Grand Prix Automatic pedals.
Old 04-05-08, 09:18 PM
archangels
archangels's Avatar
Used ob2 says SYSTEM RUNING LEAN? now what do i do to fix that problem? just bought 30miles later the cel went on, if running lean what are the list of things needed to fix? thanks
Old 04-05-08, 09:35 PM
Nad1370
Nad1370's Avatar
Usually it's your MAF meter.
Try cleaning it first with contact cleaner or brake cleaner if it's dirty.
Also check your vaccum hoses around the intake if any came loose.
Old 04-06-08, 12:33 AM
archangels
archangels's Avatar
thanks brother for that advise.... i will see, is that the crc can that is specifically made for mass air sensor cleaner where you spray in the tube into the mass air sensor needle? and is it true that the mass air sensor determines how much airflow and fuel and etc? thanks and what is maf again i forgot... thanks buddy
Old 04-06-08, 10:16 AM
Lexmex
Super Moderator
Lexmex's Avatar
It's part of the equation. MAF checks velocity and air temperature of your incoming air, but the A/F sensors on both banks of your manifolds are also the other part of the equation. They both help determine the amount of fuel going into your engine.
Old 04-06-08, 02:48 PM
archangels
archangels's Avatar
so what do i do from here? check all hoses on air intake complete and spray crc mass air flow cleaner into the maf needle? dirt can make these things happen?
Old 04-06-08, 02:53 PM
Lexmex
Super Moderator
Lexmex's Avatar
Run some fuel injector cleaner also.
See the thread at the top of the RX300 forum about gas mileage and clean the areas related to the IACV system as noted. That gets dirty in large part to the crankshaft ventilation system. Mine gets dirty also because I do not run an air filter (I tried and actually lost power, but we will see at sea level in about a week).
Old 04-07-08, 07:44 AM
lexus114
lexus114's Avatar
You said system running lean,but what code did it give you?,so we can pinpoint the problem.Or at least try too.
Quick Reply: All 2001 rx300 please advise!!! Check engine?
