Any way of checking
Do this at your own risk ...
Take a rag and with the RX in park at idle, try to plug the exhaust. You should not do that too long as eventually your engine will stall [and if it does you will have deposit on the spark plugs]. If there is a weak spot the exhuast will leak from there. For a sound system, the back pressure will build and the engine will lower in rpms.
Salim
Salim
It Seems as though
When my left rear window is open and I am by a retainig wall it seems loud.....
I dont know if that is normal and with my too lean CEL...was just wondering.
Also that pic that shows where to look for a crack just below catylitic converter seems okay but rust has made it not as clear..
There is an air pressure issue that causes that noise when just rear window is open. Exhaust leaks usually have a fluttering sound and the likely culrpit is this area here when that occurs.
