engine oil and tranny oil question please advise. thanks
i got a 2001 lexus rx 300 day before easter and don;t know much about these things, i was wondering how many quarts does this rx consume as i bought castrol 5w30 oil but i will switch over to synthetic mobil1 oil next oil change, also i was wondering when do you put new tranny oil (how many miles) and tranny gasket and filter and what oil to buy and where to buy the stuff for this so i can just pay labor costs to my mechanic thanks for your help
oh also how many tranny oil quarts and what brand weight and etc thanks
The best investment you can make is buy the workshop manual Volume 2.
Visit your local dealer and get a printout of services performed by Lexus. You can work out a service plan, with them and then choose the best place to get them performed [DIY, your mechanic or at Lexus].
There are some diy posted here in this Forum and others which you can follow.
Synthetics are great but regular oil is fine too. Just watch out for leak when you switch and remember not to go back to regular oil after extended synthetic use. My RX takes 5+qts with a filter change. I buy my filter + crush washer from Lexus.
Transmission service, typically is drain and fill. Some avid DIYers drop the pan and change filter. I buy my transfluid + crush washers from Lexus. I do a drain fill at 30k miles. The Lexus parts knew how much fluid I would need and sold me that many bottles. [That is exactly what I needed when U drained from the two places.. FWD].
What brand and how often the change is all debate-able. You can use the manufacturer's recommendations as minimum.
Some of the information you seek is in the owner's manual. Most of the other is in the workshop manual.
Salim
Salim
Salim
Salim
does anyone know a good best tool to use on taking oil filter off? i have a 2 prong claw type that is not working due to length, can any none post a pics, are end caps better thanks
Well you need to determine which filter you would use.
I have a band tool which squeezes the sides as you spin the filter off. Sice the band is loose, I add couple of layers of mesh sandpaper (used to sand down sheet rock).
Salim
Salim
archangels
RX - 1st Gen (1999-2003)
04-13-08 01:49 AM
