Should I change my transmission fluid in a high mileage RX?
do you guys always buy your ATF from Lexus/Toyota or do you use something from say like advanced auto parts. I see where they carry the correct type of fluid (TIV I think, don't have my book w/ me) but not sure if I should use that or the Toyota/Lexus stuff.
Just dont get confused at the auto parts stores, Dexron IV is not the same stuff. The only fluids other than Toyota Type IV are: Mobil 3309 or AMsoil ATF synthethic.
Super Moderator
Amsoil I bought at Carquest. In fact they seemed to have virtually ever other Amsoil lubricant available there. As far as changing it out, I didn't follow any Amsoil or any other method, just the same drain and fill that I always do (tranny pan and front differential).
Is this what you used? Does Amsoil have another ATF or just the universal?
I'm looking to try this out after I finish whats left of a case of Type IV.
https://www.amsoil.com/storefront/atf.aspx
Super Moderator
That's the stuff. Really happy to finally get this into my tranny. Today Actually had my friend Michael who has a Corvette Z06 change out to Amsoil ATF in his car, since Dexron III can be substituted by the Amsoil ATF (we also added Castrol 0W30 for his oil and Royal Purple for his differential).
Super Moderator
I think it is also an excellent oil. I am going to consider trying it next oil change, (since I saw it the other day at Carquest), as a test.
Keep in mind, I HIGHLY recommend the Castrol 0W30. It was very much pushed through its paces by me back in Mexico (and also many track friends who paid $15 USD a liter, some $30 USD a liter) for it and were extremely satisfied with it. In Florida, it has a relatively tranquil life, so we will never fully know if Amsoil would have done better. I knew a guy at the U.S. embassy with an RX300 and he ran 5W30 Amsoil (had it imported) and found it quite adequate. I think he was running 5 to 6K drains on it with no loss in consumption.
Okay, I have 99 RX300 that we bought from family, and to be honest I can't verify what if anything was ever done to it. I was going to flush the tranny, but have decided against it at this point. I want to drop the pan and replace the filter. Where do you guys buy your tranny filters from? I have heard mention of filter replacement kits, but have not yet found those. Any help is appreciated.
smerre,If you have a Carquest down their in SC,that is where i got my filter kit from.What i liked best was,it came with the factory type screen,not the paper element kind.I have found it to work well so far.
I'm not a trans. mech. but I do know a little about vehicle maintenance. (and a few other things
) If it were my car I would always pull the pan and clean ( if screen) or replace if fiber. When I did my DIL's Rx I pulled the line from the trans. to rad. and pumped the old fluid out as I filled the trans. until the fluid came out nice and pretty red. (it does it pretty abruptly when all of the old fluid is out). That way I have changed ALL the fluid at one time and am not going back 2 or 3 times to change the fluid . And though I admit if you change it enough times (pan) it will pretty much do the job- you will NEVER get all of the old fluid out that way and at $4.50- $7. a quart you will use more fluid in the process of not changing ALL of the fluid. Just the way I prefer to do it. Ya pays your money, your entitled to do it any way you want to- BUT BY ALL MEANS DO IT! Don't do the flush and don't listen to the guys that say not to change it above 80k if it hasn't ever been done. That's nonsense. I would hate to think that the dirt inside the transmission was the only thing holding it together. Oh, and did I mention- don't do the flush!![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Did you clean your screen? If so what did you find? I want to do mine but I remember a post awhile back claiming the screen was a sealed box with inlet and outlet. Can anyone confirm this? You couldn't see the screen and it was difficult to clean. If that's the case I may just order a new screen online. Definetly don't want paper or fiber.
Super Moderator
You can see the screen, but not all of it. There is a hole at the top and you can see in. See this thread, https://www.clublexus.com/forums/sho...d.php?t=347216
Incidentally, I had to leave that old tranny behind in Mexico. I wanted to see what caused it to fail (that was the RAV4 tranny), but it just weighed way too much and we were already weighed down.
I usually pick up my filters (paper ones though) at Toyota and just ask for the 1st gen V6 filter along with gasket.
