Torque Wrench Recommendation
Is it really true that over torquing your lug nuts on your wheel can really warp your brake rotors over time?
I did some searches and find that to be the common opinion on this board (and other car boards as well).
Can someone recommend me a nice and preferably long (for the leverage needed to unscrew the lug nuts that are on pretty tight - because of the lovely air wrench they use at the shop) torque wrench that you use.
I went to Sear.com and saw that people left some nasty reviews of Craftsman tools....
Thanks.
Thanks.
No one should use torque wrench to undo. [unless there is no other option].
Get a breaker bar.
Torque wrench has calibration issue and that is where the quality of the tool is. Harbor freight has the cheapest torque wrench.
Salim
Get a breaker bar.
Salim
The key is using one at least puts the same torque on all nuts and dont forget to use a crossing pattern to apply torque. The Harbor frieght ones are just fine. If it isnt calibrated within 5 lbs no big deal just putting them on evenly is important.
I'm pretty dense when it comes to working with tools. Just exactly how do you set the torque (say, 76 ft/lbs) on these tools? They look like they just have a little clicking thing that makes it turn either clockwise or counter clockwise. These things have numbers on them??? Also, assuming these things have some positions on the torque setting like an electric drill, does it go "loose" or not tighten anymore if I reach a certain amount of tightness on the lug?
Again, I may be asking very rudimentary questions.... the last time I used a torque wrench (for a non-automotive repair), it didn't have any numerical settings. So I kept on tighten, click, tighten, click, tighten... then "bang" the bolt broke in half.
I have a sears torque wrench. i have to get it recalibrated, because it was off by 2ft/lbs ever since i bought it :[. i heard the harbor freight stuff its really good.
pretty much how it works is that you set it to the torque you want. my lexus mechanic told me to set my torque wrench at 80ft/lbs. so once its set you start tightening the lug nut. when you reach the 80ft/lbs that you set the torque wrench will make a clicking noise. for sure use the cross pattern. they have electronic torque wrenches that make a beeping noise and etc. my lexus mechanic also warned me to not over tighten my lug nuts because it creates warpage.
Ratchet Action:
Like a valve which lets you free move one way (with clicking sound as the pawl slides off the catches). Ex: You tighten 1/4 of turn and then move back 1/4 turn with ratchet action. Do it four times and you have turned the nut/bolt one turn. This is not a torque wrench .. no calibration ... expert mechanics can feel how tight the nut/bolt is. Note: The breaker bar we mentioned does not have the ratchet action so it is more stout. Typically they are referred to as "drives" 3/8 or 1/4 the size of the end cube. For automotive work you need 3/8"
Torque Settings on drill machines:
The drill stops turning once the torque is achieved .. thus preventing stripping. [I am old fashioned .. never own/use this stuff]. I have no idea if the torque is calibrated or just 3 is more than 2 etc.
Torque Wrenches:
electronic: The piezo device shows the torque.
Beam type: A pointer moves over a scale and you can read it.
Click-type: Here with a dial you set the torque ans when you reach the set amount the tool either flops or makes a click sound. [these can be ratcheting types ... where you free spin it in reverse direction ... making clicking sounds].
You need to pay attention in setting the torque .. One spin of the dial can change more than ONE least significant digit. Hard to explain but play aound and you will figure it out. Make sure you use the lb-ft or Nt-m correctly.
Last of all to use the torque wrench right you have apply the force from the right spot ... to develop the moment-arm.
Salim
