Throttle please advise!?
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Good looking out LEXMEX and salimshah!
1. My ES' response feels like a 'brand new' 11 year old car
nah but seriously my engine / transmission / powertrain doesn't have the awkward hesitation between 2nd and/or 3rd gear after decelerating without stopping then proceeding to accelerate while driving on the highway.
2. Acceleration pedal is MUCH more responsive.
3. Up and down RPM syndrome is gone (This started to occur yesterday)
4. No more jump into DRIVE or REVERSE after shifting from PARK.
5. Purrs smoothly at idle
*FYI if anyone has way too much slack on your acceleration cable (I personally had 1-1/2" - 2" play up and down), IMO I highly recommend this adjustment. I almost thought my tranny was slipping or starting to go bad.
Thanks fellas.
Thanks fellas.
My 98 ES300 throttle cable slack too, the bolts aleady moved to the left max. But it is still slack.
Have to add the spacer at the gas padel to shorten it.
The result is big difference!!!
The jump/shake of gear-shift 1-2 , 2-1 and Reverse were much improved.
Hope this helps!
![](http://i10.photobucket.com/albums/a102/udownload/Car/CableSlack.jpg)
![](http://i10.photobucket.com/albums/a102/udownload/Car/Spacer.jpg)
![](http://i10.photobucket.com/albums/a102/udownload/Car/Spacer1a.jpg)
Hope this helps!
![](http://i10.photobucket.com/albums/a102/udownload/Car/AdjustmentDone1.jpg)
Super Moderator
Just did this mod and it seams to make a big improvement, I would only add that you will need to use a set of "Robo-grip" pliers to keep the throttle cable from spinning and I would start with the left nut 1st (mine were 1/2 inch)
Chet
Chet
ItzFilyO
04-21-18 10:46 AM
