Lexus Rx300 Full Set Pedals? Look!
I saw these on ebay i thought they looked kool the seller said you would have to drill your footpads to put these on:
http://cgi.ebay.com/ebaymotors/Alumi...spagenameZWDVW
does anyone know where to buy a full set of metal pedals that are screw on or something looking for full set... thanks or does anyone know any kool rare items for this rx300 that i might be interested i bought this kool light that flash dances to the beat of music, also i was looking at headunit radio looks like you can't add upgraded unit due to ac functions ***** and etc, i went to best buy and a guy said headunit adds more better sound?
Super Moderator
The Momo pedals I have had on my RX300 for years had to be drilled into the existing pedals just like this seller mentioned. I am not sure offhand if you can just removed the rubber on the existing pedals and put these in.
ron so you had to drill through rubber to put on do they stay snug tight? i thought yours was screw on? then i might consider this? is it hard? thankswait drilled through rubber or metal? thanks ron
Super Moderator
Yes, had to drill through the rubber. Never have had an issue with that part.
Only issue I have had with my pedals is that the accelerator pedal is long and would go into the carpet. I had to not only remove the carpet but also cut up part of the actual floor, so I could obtain the greatest possible opening of the throttle body (fully horizontal). But again, I am not much on style on these points.
sleepybobcat
RX - 1st Gen (1999-2003)
10-20-03 08:01 AM
