RX 300 Pulsating Brake pedal
Thanks for the info -- my mechanic did change the right rear ABS sensor -- because of his read of the voltage -- BUt it did not fix the problem -- he said the part was $200 -- and did NOT charge me -- Monday - Lexus has a shot -- I assume they have a computere to diagnose the issue ...but I know -- bad to assume....
If it is the ABS sensor ring -- and I don't have it fixed (because of the cost) -- besides keeping the pulsating brake pedal -- will I incur any further damage? (Strange, my 200K Maxima never had this problem)
Hi rick,I would not play when it comes to brakes,they are the only thing you have,to stop our 4,000 lb RX.Just to try and narrow it down,did you pull the fuse for the abs,to see if that changed anything?
ABS wheel sensors send an AC sine wave voltage at a frequency (frequency based upon speed of the axle) to the ABS computer. ABS computer evaluates the frequency of each axle, and if one frequency is lower by a certain percentage than the other axles with the brakes on, the system actuates the ABS system. A few people have had this problem including me. I put a scope on each sensor, it appears the rear pass side sensor has a problem. I will replace and let you know the results
Duane
Duane
If it were me, I wouldn't be happy paying close to a grand (just my guess), but I would pay and keep the safety of ABS.
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I have ABS actuation just before stop with no diagnostic codes. What I am seeing is 3 sensors outputting a millivolt sine wave AC signal (250 - 400 mV). The fourth sensor is outputting 3 volts. Cannot figure out what would cause a larger voltage signal. The air gap between the sensor and reluctor (toothed ring on the axle), the reluctor condition, the sensor condition, magnetic strength of the sensor etc all go together to produce a correct signal. I quess I would rather see the axle reluctor causing the problem, a new axle is cheaper than the sensor.
If you remove the 60 amp fusible link, it is bolted in from the bottom. If you try to pull it without removing the bolt, it will break, don't ask me how I know:
I wish I could just pull the suspect ABS sensor, but it is corroded into place. The other rear sensor I pulled last summer got destroyed in the process. I quess I could pull the axle and inspect.
The service manual pretty much talks about checking what I mentioned above. Probably just pull the old sensor out, which will probably destroy it, and put in a new one and see what happens. Poke and hope for the best.
UPDATE...FIXED...ABS issue...Pulsating brake pedal....the dealer identified the issue..."broken tone ring on left rear axle"...$900 for the part and $550 for labor...repaired in about 2 hours...but they charge the flat rate....at 90k miles on mya alledged high end auto -- I don't expect $1500 rerpairs for an obvious inferior design/part...too bad....
I am having a hard time figuring out what that part is, but the one I found on the Lexus park place site was only $547....if it is the right part...
http://www.trademotion.com/partlocat...20&catalogid=1
Just sell the ring, you have to purchase the entire axle ($900).
I had to take apart all 4 axles and surely it was the last one that had a crack on the sensor ring. The abs light never turned on so did not have a way to know which axle was giving me the problem. All speed sensors were good.
Sounds like the issue I'm having with my 02. Pulsating feeling when braking, no warning lights. Excellent! I wonder if it turns out to be this issue, if the warranty I purchased with the car a few weeks ago would cover it.
It could be the rotors (if there warped)... have they been changed?
