RX 300 Pulsating Brake pedal
#46
You are much more productive than I am. I have a new ring that has been sitting forever waiting to be installed.
Any issues with the half-shaft to differential bolts? With old cars I'm always concerned about snapping old fasteners.
#47
#48
As for the bolts, heat them with a torch just in case. Better be safe than sorry.
#49
#50
Abs light is ok
But brake pulsating
Have change abs,disc,caliper,pad
#51
A common cause is cracked or loose ABS reluctor rings. There are plenty of threads on it.
You can readily prove it by disabling the ABS. Different ways to easily disable it are also in the threads.
The following 2 users liked this post by maxSteel:
Margate330 (12-26-20),
salimshah (12-26-20)
