RX300 Steering Colume whine
Old 05-07-08, 11:37 AM
Sporty
Sporty's Avatar
Default RX300 Steering Colume whine
Greetings fellow Lexus owners!! Wondered if you can help. I have a Lexus RX300. When I turn the steering wheel either direction with the motor running (either driving or sitting still) I hear a whinning noise...doesn't matter if I adjust the tilt wheel...still whines. Any ideas?
Old 05-07-08, 11:54 AM
bob2200
bob2200's Avatar
Welcome to ClubLexus. There is a rubber gasket where the steering column passes through the firewall, visible from under the dash. It has been written up that this can cause noise when the steering wheel is turned. The solution is to lube it (the rubber to steering column interface) with silicone spray or grease. I'm assuming that this is the type of noise you're hearing.
Old 05-07-08, 01:11 PM
Sporty
Sporty's Avatar
Thanks for the reply...I will check that although when I hear the noise it does not appear to be coming from up under the dash where the steering colume goes through the firewall....it sounds like a "cat whinning" and it appear to be coming directly from the steering colume in the area behind where the steering wheel attached to the colume....the whine is very precise (louder when you turn wheel more - either left or right) and is not intermittent.
Old 05-07-08, 01:13 PM
mwbuck
mwbuck's Avatar
maybe its the power steering pump?
Old 05-07-08, 02:37 PM
bob2200
bob2200's Avatar
Is the power steering fluid level OK?
Old 05-07-08, 04:14 PM
smerre01
smerre01's Avatar
my thought exactly, I bet it could be the pump either low on fluid or going bad.
Old 05-08-08, 08:02 AM
nocaster
nocaster's Avatar
Mine does the same exact thing. Sounds like my dogs moaning when she wants food.
Old 05-08-08, 08:09 AM
lexus114
lexus114's Avatar
Ha,sound`s like that describes it pretty well
Old 05-09-08, 07:35 AM
Sporty
Sporty's Avatar
just got a call from our mechanic...said he lubed a boot and it took care of it! Thanks everyone!!
lexuschar
RX - 3rd Gen (2010-2015)
12-04-16 01:13 AM
tomstep2
21
03-01-14 04:36 PM
jishan
13
12-07-07 06:57 AM
Flyrockies
12-06-05 10:05 PM
Quick Reply: RX300 Steering Colume whine
