will 18x9.5 wheels fit on a rx300?
Old 05-08-08 | 04:51 PM
crocair's Avatar
crocair
Default will 18x9.5 wheels fit on a rx300?
The offset is +20.
If so, what tire would fit
Keepdabeat, i hope you can answer.
Old 05-09-08 | 02:45 AM
iKon_RX's Avatar
iKon_RX
though you posted this in the wrong section. i can only tell you that would would mostly need about 10mm spacer in the rear. you should be using 245 for withd of tire
Old 05-09-08 | 12:10 PM
KeepDaBeat's Avatar
KeepDaBeat
I'm not really sure. I wouldn't push more than a 9" width on the RX though. You could make it fit with spacers but it would just look bad. And I'd also highly recommend a wheel bigger than 18" for the RX. You're gonna make it look like a minivan if you put 18's on it. Unless you plan on doing a LOT of driving with it, at least find some 20's. But even with 20's you can put a 35 series tire on it, which has plenty of cushion.
Old 05-09-08 | 12:15 PM
KeepDaBeat's Avatar
KeepDaBeat
Here ya go, get these bad boys.
http://www.discountedwheelwarehouse....ShowLarge=True
Big deuce deuces with a nice size lip! 22x9 fits the RX perfectly. Man, those would look sick.
PhoenixAsh
12-01-16 02:54 AM
John_Smith
04-21-08 06:15 PM
Philly RX
12-28-05 08:52 PM
flossn
10-22-02 12:23 PM
Mercy522
09-01-01 12:10 PM
