Why do Japanese Harrier owners love to add 25mm wheel spacers on stock wheels/tires?
Old 02-14-02, 12:51 AM
Mike Schriber
Mike Schriber's Avatar
Keep in mind that spacers will put more stress on your wheel bearings and will wear them out faster. Also, make sure any spacers you get are hub-centric.
Spacers will add some stability to the vehicle, but it's not going to be huge.
Mike
Mike Schriber is offline
Old 02-14-02, 02:23 AM
sleepybobcat
Registered User
sleepybobcat's Avatar
Good point... I've been wondering about the additional
stress as well. Will larger/wider/heavier wheels(18" or 19")
do the same to the wheel bearings?
sleepybobcat is offline
Old 02-14-02, 11:32 PM
Mike Schriber
Diameter doesn't matter, but wider adds some additional stress (not too much though). Running a bigger offset to fit wider wheels does add more stress.
Mike
Old 02-15-02, 09:36 AM
willard west
willard west's Avatar
Default bearings
Factory wheel "offset" design is generally such that the wheel bearings are "centered" to the center of the wheel itsself, moving the center of the wheel outward puts different, worse, stress points on the bearings.
Todays wheel bearings seem to last well beyond 100k miles so I suspect you won't see any affect unless you go beyond reason, wheels/tires extend beyond fender lip.
Simple math indicates 3" wider stance than OEM 60" would add 5% more lateral stability.
willard west is offline
Old 09-25-03, 08:29 PM
Rockero28
Rockero28's Avatar
Default 25mm spacers
I got my H&R 25's at Off Road Warehouse for $110. I think RMM sells them higher, but they are the same H&R spacers. And yes, it will make a diference in looks and driving performance.
Rock
Rockero28 is offline
Old 09-26-03, 04:03 AM
Daddy-O
Daddy-O's Avatar
Wow, this thread is 1 1/2 years old.
Daddy-O is offline
gsfdream
GS F (2016-present)
70
07-22-23 06:53 AM
grekt
05-16-17 07:26 PM
808mcv20l
12-15-15 09:49 PM
krue92
IS F (2008-2014)
09-12-11 06:06 AM
gs4to4
Suspension and Brakes
13
08-01-01 03:53 AM
Quick Reply: Why do Japanese Harrier owners love to add 25mm wheel spacers on stock wheels/tires?
