A/C Took the day off
Hey guys, here in Northern California we're having a pretty nice heat wave and today my A/C decided to just blow hot air at me, everything else seems normal. The radiator fans still come on when i switch on the A/C but it only blows hot air even on MAX COLD. I checked the low-pressure valve and the PSI seems to read normal, what can I do or what may be causing this problem here?
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
It could also be the hot valve has failed in the on position or the controls to it have failed for the same reasons the blend doors might. Good Luck. Let us know how those things check out.
Sorry- I beleve it's where it comes out of the a/d that it should feel cold. And I'm not sure you have a traditional a/d like I'm used to on american cars.
