High Brake Light Replacement
I have a 2000 RX300 and need to replace one of the high brake lights in the top of the rear door. Is there a specific way to take the plastic trim off so I don't break any clips off of it?
Hi spike,I did mine a few months ago.It didn`t burn out,the bulb itself got so black,that the light became dim.Anyway,its real easy,just pull the top part(the top of the hatch door plastic) off,then you will see a couple of screws to dismantle where the bulb actually is.Once you get the plastic trim off,you will see how easy it is.Piece of cake.If you have any trouble,were here.
