Bluetooth Car Kit For 2000 Rx 300 ?
Old 04-23-11, 07:35 AM
  #31
Kansas
Kansas's Avatar
gazi001, here is another diagram that might help you find a telephone mute pin/wire if you cannot locate a connector containing a mute that was meant for a dealer installed Lexus phone.
One of the connectors at the audio system amplifier should contain the same violet color mute wire contained on the telephone system connector that would have plugged into the telephone ECU if your car had one of those.
If you look at the audio system diagram I posted earlier on this thread, you will see that the violet telephone mute wire is labeled "TMUT" at the amplifier. "TMUT" = "telephone mute".
You should be able to verify the TMUT pin/wire at the amplifier by using a grounded unpowered test light per the photo I posted earlier. When you touch the TMUT pin on the amplifier with the test light's probe, your radio and CD should mute.
If fact, once you locate the amplifier and the TMUT pin, you might be able to follow the cables and find the telephone connector that sleepybobcat found.
Attached Thumbnails Bluetooth Car Kit For 2000 Rx 300 ?-2000-rx300-audio-system-amplifier-location.jpg
Old 04-23-11, 01:58 PM
  #32
gazi001
gazi001's Avatar
Thanks Jim. I will check next weekend if the weather is good in NYC .
Old 04-26-11, 06:41 PM
  #33
gazi001
gazi001's Avatar
Sorry Jim this is not harnesse cable holder. It's a rear passenger side stop light power cable connector. I found it last sunday when i re-open the whole trims and trunk for exploring again for mute connection in the trunk. It took me few hours. Here is the pics again.
Attached Thumbnails Bluetooth Car Kit For 2000 Rx 300 ?-rear-pass-side-lamp.jpg   Bluetooth Car Kit For 2000 Rx 300 ?-rear-pass-side-signal-lamp-connector.jpg
Old 04-26-11, 06:56 PM
  #34
gazi001
gazi001's Avatar
Now finaly i got the conclusion for mute wire in the trunk for 2000 RX 300 without navigation is not there. I guess only 2001 or higher models may be the mute connection in the trunk. I open all the trims right and left, remove the spare tire, open the back seat trim and the amplifier. The Amp has 3 cable connectors which goes under the carpet all the way to the front to the head unit(radio). I didnot remove the carpet all the way to the front so. Here are some pics of the amp, 3 cable connectors and exact location for pioneer amplifier who interested to see.
Attached Thumbnails Bluetooth Car Kit For 2000 Rx 300 ?-amp-pos.jpg   Bluetooth Car Kit For 2000 Rx 300 ?-amp-position.jpg
Old 04-26-11, 06:59 PM
  #35
gazi001
gazi001's Avatar
Here are the three connectors for the pioneer amplifier.
Attached Thumbnails Bluetooth Car Kit For 2000 Rx 300 ?-amp.jpg   Bluetooth Car Kit For 2000 Rx 300 ?-amp-opp.jpg   Bluetooth Car Kit For 2000 Rx 300 ?-amp-opp-way.jpg   Bluetooth Car Kit For 2000 Rx 300 ?-3-conn.jpg   Bluetooth Car Kit For 2000 Rx 300 ?-3-connecors.jpg
Old 04-26-11, 07:03 PM
  #36
gazi001
gazi001's Avatar
Connectors cable goes to the carpert all the way front.
Attached Thumbnails Bluetooth Car Kit For 2000 Rx 300 ?-3-conn-cable-goes-front.jpg   Bluetooth Car Kit For 2000 Rx 300 ?-3-connec-cable.jpg   Bluetooth Car Kit For 2000 Rx 300 ?-3-connectors-cable.jpg   Bluetooth Car Kit For 2000 Rx 300 ?-3-connectors-amp.jpg   Bluetooth Car Kit For 2000 Rx 300 ?-pioneer-amp.jpg
Old 04-26-11, 07:05 PM
  #37
gazi001
gazi001's Avatar
More pics of each connectors.
Attached Thumbnails Bluetooth Car Kit For 2000 Rx 300 ?-ip-connector-1.jpg   Bluetooth Car Kit For 2000 Rx 300 ?-ip-midd-connector.jpg   Bluetooth Car Kit For 2000 Rx 300 ?-ip-connector-3.jpg
Old 04-27-11, 04:05 AM
  #38
Kansas
Kansas's Avatar
OK, you are doing great and almost there. With the connectors plugged into your amplifier and the radio (and then the CD) playing, find the violet (TMUT= Telephone mute) wire and touch the grounded unpowered test light probe to the pin in the connector that the violet wire leads into. You should be able to slide the test light probe - assuming it has a sharp probe like the one in the photo I posted - right past the wire leading into the plastic connector. Your radio/CD should mute when you ground the TMUT mute pin.
If you can't tell which wire is the violet one, test all the connector pins. That is what the pros do and you aren't going to hurt anything as long as you don't touch two pins at once.
Once you find the TMUT wire at the amplifier, connect your telephone kit mute wire to it using one of the methods I described previously.
It is quite possible that only gen 1 RX vehicles with navigation were prewired for phones and that a Lexus dealer installer had to run additional cables when installing a Lexus phone into RX vehicles without navigation. I've been amazed at the amount of disassembly it sometimes takes to install dealer installed options and accessories into Lexus cars.
Old 04-27-11, 06:30 AM
  #39
thomas1
thomas1's Avatar
my 99 RX without nav had the mute wire...it is there.... I installed the Motorola H850 bluetooth and it worked great.
Old 04-28-12, 09:24 PM
  #40
gazi001
gazi001's Avatar
I finally got the Telephone mute wire from the amplifier plug S17 pin # 9 (violet color) circle red in pic. Now when I got a call the radio get mute totaly and no problem at all. Thanks for your help guys. Sorry for discussing the old thread again.
Attached Thumbnails Bluetooth Car Kit For 2000 Rx 300 ?-amp-plugs-lexus-rx-300.jpg
Old 04-29-12, 06:11 AM
  #41
Kansas
Kansas's Avatar
Congratulations, Halim. I like finding people who are as "crazy" as me. Never give up!
Old 04-29-12, 08:54 AM
  #42
thomas1
thomas1's Avatar
Yea...I still have a Motorola HF850 laying around in the garage..Was trying to talk daughter into it on her car...Kids dont listen even when adults..
Old 04-29-12, 10:28 AM
  #43
gazi001
gazi001's Avatar
Thanks Jim and Thomas. I tried my best.
RJPLexus
RX - 3rd Gen (2010-2015)
04-02-13 05:52 AM
CCJ22
11-22-12 10:35 AM
winsalem
08-29-05 10:53 AM
RastaForI
08-23-05 10:41 PM
gboothe11
08-24-04 07:25 AM
Quick Reply: Bluetooth Car Kit For 2000 Rx 300 ?
