spare tire
They didnt start suppling the regular wheel spare until 2001.Most little changes took affect in 2001.Full spare,hi/lo seat heater,larger capacity fuel tank,black leather interior,vsc.
when you said regular, are you saying the spare tire has the same wheel as the other 4?
The reason I asked is... I took my car to the shop to have all 5 tires replaced the other day. When I checked the spare tire last night, it has steel rim on it. I remember the spare tire has the same alloy wheel as the other 4 when I purchased the car new. Did the shop do the switch or is my memory isn't correct?
I think what Lexus114 is saying is that, unless you paid extra for a 5th alloy wheel, you got a steel spare wheel as standard equipment in 1999. I reason I word it this way is that I have a 2002 model and got the 5th alloy wheel as standard equipment.
Out of Warranty
That's correct as far as I know, my 2000 RX 300 had a black spoked steel wheel for the spare, That's really kinda dumb on an AWD where you want to rotate tires to even up wear - otherwise you end up replacing a spare every 5-6 years that has never been on the ground but may be dry rotted.
That's correct as far as I know, my 2000 RX 300 had a black spoked steel wheel for the spare, That's really kinda dumb on an AWD where you want to rotate tires to even up wear - otherwise you end up replacing a spare every 5-6 years that has never been on the ground but may be dry rotted. ![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
