alignment?
everytime you buy new set of 4 tires is it best to get a 4 wheel alignment? how would you know if you need one? and what happens if you buy 4 new tires but don't align is that bad? thanks
the advice I have always gotten is that you should get an alignment with the new tires - that way you can ensure even tread wear. If you are out of alignment, it isn't a good way to start out with your new investment. I have heard from others that some tire dealers will balk on tire warranty if you have had an alignment. Its worth it to spend the money and have the alignment done.
the advice I have always gotten is that you should get an alignment with the new tires - that way you can ensure even tread wear. If you are out of alignment, it isn't a good way to start out with your new investment. I have heard from others that some tire dealers will balk on tire warranty if you have had an alignment. Its worth it to spend the money and have the alignment done.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Will tell you though it has a lot to do with how they are wearing. I just did my very first alignment on the 99RX and everything was on except toe...
it has 152k miles on it and it did well on all the tires I put on...
Also has something to do with how many curbs you hit...
Super Moderator
archangels, I feel your pain.
A tire place near me charges $89 USD for a 4 wheel alignment on the same exact Hunter machine that back in Mexico would cost me about $25 USD if I were a first time customer without connections.
What I do is find a dead street, usually late at night and I run down the middle of the street very slowly with the steering wheel track dead center and see if the steering wheel starts to fight me in one direction or the other. I also make sure my tire pressures are all equal. In Mexico City that was hard to find, but usually the top of shopping mall parking lot worked just fine. In fact I did just this after buying two rear tires back in Mexico and then another two for the front just last week here in Florida. Found a parking lot at night and I ran it and no issues.
Now, this doesn't mean I don't have bad alignment. However, if I started to see funny times in the 1/4 mile like I did in Mexico or here in Florida strange mpg out of the norm (just starting and E10 complicates things) then I start to suspect alignment as a possibility.
Wow, here in northeast... you'd be lucky getting by one year without having to do something to alignment. I had the "luck" of having to get two alignments done one month apart from each other because I hit a pothole about the size of Rhode Island on the BQE back in '92. The roads have not improved much in 16 years here. Wish we had smooth mountains road in NYC...
Wow, here in northeast... you'd be lucky getting by one year without having to do something to alignment. I had the "luck" of having to get two alignments done one month apart from each other because I hit a pothole about the size of Rhode Island on the BQE back in '92. The roads have not improved much in 16 years here. Wish we had smooth mountains road in NYC... ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Yes I am the original owner, and the tires wore evenly. The steering wheel finally ended up crooked, that Is why I had it aligned. I guess my wife is a great driver and avoids the curbs...seems any damage to her car has been from me (not good) Yes California doesnt have those potholes, I remember when I drove back east....
There are 3 factors that are based on alignment:
1. Driveability (out of whack to be noticed)
2. Tire_wear (needs to be caught in time, else your tires are ruined. How bad , directly affects the rate of wear)
3. Fuel economy .. roll (very hard to perceive)
The specified (by manufacturer) alignment numbers that the mechanic tries to get to cause a slight tire wear but they improve driveability. The rotation (back and front, 4 wheel exchange or 5 wheel exchange pattern) keeps the tire-wear some what even (or gets you the most miles from the tire).
I have not had abnormal wear and experience no-pull that I have to constantly fight, thus I have had no reason to have the alignment re-done/checked since I bought the RX. Now if I was to invest in top $$$ tires, I might get the alignment done.
Salim
Salim
If I don't have abnormal tire wear or any pulling, I stay away from an alignment. You run the risk of them taking your perfect alignment and knocking it out a little. Even the best front end guys are paid by volume and are in a hurry.
kool thanks for your reply i will test my alighnment to see if its good like lexmex said to test at mall because of straight roads. but yeah i kinda was thinking what you were about that perfect alignment from factory... thanks buddy
