Trans pan feels hot
I would really like to know what temperature these trannies. operate at.in the summer.During the colder months here in the north east,I can place my hand on the transmission pan,(after driving)and hold it their because it`s not real hot.Now with temps in the 90`s it feels like its running at very high(almost inoperable temps)I have been in the automotive field a while,and I know its probably running at least 190-200 degrees.Is their a radiator cooler on this vehicle as well?Or just the external cooler?Any one have any input re;this?I can only see the ext.cooling lines.Maybe I should install another cooler in the front of the vehicle.I am concerned because heat is an automatic transmissions worst enemy.I may add a bottle of Lube Guard witch is supposed to lower the temperature of the fluid.
Super Moderator
When I was in Mexico, I often poured (as a test) a bit of water on the top of the tranny and would see if it would bubble or not after running at the track. That was also an indication for me that the transmission fluid needed changing.
Lex,have you noticed any shift improvements using the Amsoil?My fist to second gear is my worst shift point(kinda slips @ times) my other gears are fine.But when I changed my filter,on the bottom of the pan was normal wear.I also cleaned my speed sensors over the weekend.The one facing the front was clean,the one on top had slight metal particles.I did not swap them @ this time.I will probably do that at a later date.I am also surprised that lexus did not run the trans colling through the radiator for added cooling,witch would ensure the fluid would not get hotter than the engine temp(along with the protection of the cooler already in place)That is the way American cars do it,and it works out very well.
My recollection is that a transmission cooler part of the towing-prep package (at least on the FWD models). It may have been standard on the 4WD models. Which model do you have?
Super Moderator
I really cant afford to switch to Amsoil rite now,so I picked up a bottle of Lube Guard.My mercedes mechanic used it when he serviced my 300E.Supposed to reduce the fluid temp.And fortify the fluid.(yeah right)I`ll let you know my opinion on it.
Update re; Lube Guard,I put some in on tue.(i believe it was)and I like it so far.seems to have helped my 1st to 2nd shifts so far.
I believe a good normal temp for the tranny would be around 160 to 180degrees. I wish I knew what ours are running at. Maybe I will add a tranny temp guage...
mckellyb
05-01-17 09:34 PM
