RX 300 Power Door Locks problem
Old 06-24-08, 02:46 PM
nghiaho58
nghiaho58's Avatar
Default RX 300 Power Door Locks problem
I need help. Does any body know the cause and how to fix the problem of my Rx300 power door lock, . Both driver/passenger side power locks do not lock or unlock with the remote control nor with the power switch. When activate, it moves about half way. I only can manually lock/unlock them with the key. The rear doors work fine.
Thanks in advance for your help.
Old 06-24-08, 05:35 PM
salimshah
salimshah's Avatar
Received 1,098 Likes on 988 Posts
Door lock actuator relay/motor seems likely culprit. It has been discussed in the past. Try the search function. Although a different model, I have seen more in depth discussion in the GS forum.
Salim
Old 06-24-08, 06:37 PM
thomas1
thomas1's Avatar
I have replaced the drivers door lock (about 4 1/2 years ago) and it just failed again like yours. Cost $262 for the part. I am going to go this route this time:
http://us.lexusownersclub.com/forums...opic=41219&hl=
I just ordered the solenoids on Ebay and am awaiting their arrival...
Old 06-25-08, 12:13 AM
code58
code58's Avatar
Nghiaho- Good advice here- there is much more if you do a search but it's not really necessary. I did all 4 on my DIL's RX at no cost rather than the $1300. that they wanted just for the 4 motor assy's. I have a post in that thread under code58 and have posted elsewhere on it also. It's really not hard,(you do not have to drill the the arm on the orig motor assy. as the 1 poster said), and you can readily buy the generic lock assy's. all over the net for as little as $5. ea. There's nothing wrong with the quality just because they're priced cheap. Remember, you leave the orig. lock in place and just piggy-back onto it to retain all else that the lock is interfaced with.
Old 06-26-08, 05:06 PM
nghiaho58
nghiaho58's Avatar
Thanks guys for the tips. I will try to fix it myself and let you know how bad/good I did it.
TRDRAV4
19
06-19-11 08:26 PM
bullseye
05-03-11 10:43 AM
Gunnut
07-17-10 09:26 AM
newgs3
05-22-06 01:12 PM
disco_y2k
10-12-02 12:22 AM
Quick Reply: RX 300 Power Door Locks problem
