P0125... I need help... A.S.A.P.
Don't forget to check the fuse I mentioned above. Meetya had a P0125 problem a while back and it turned out to be this fuse.
I just talked to the guy at Oxygensensors.com and he told me that my dad replace bank 2 sensor 1.. so he replaced the wrong one... i found a picture in the forum of where bank 1 sensor 1 is located.. but I need help... from which point of view was this picture taken.. from under the car?...
thank you!.. you guys have been so helpful...
[img]http://alflash.com.ua/RX/_3442_1.jpg[/image]
Yes, back of the engine shot from underneath.
Yes, passanger side. If you slide under the car just behind the passanger side front tire and look up between the driveshaft and body you will see it. It is about even with the back of the passanger side tire. Print out the pic and take it under the car if necessary. It helps to have a set of ramps to drive up on to do this.
I used the same Walker sensor I had order from Oxygensensors.com and placed it in the right place (B1S1).. and placed the original removed sensor (B2S1). and it worked...
